Coilovers with OEM 18" Aristos, do I need to roll the fenders?
General Maintenance, Repair and Troubleshooting. Questions and DIY
t0kie
Postby t0kie » Sat Aug 01, 2009 11:43 pm
My car is 03 GTI 1.8T FWD, AWP engine with 18" OEM Aristos wheels and will put 225/40/18 tires all around (now still have Kumho Ecsta MX 245/40/18 installed that I'm trying to sell/trade them with 225/40/18, anyone interested please let me know too).
I'm planning to put FK coils & have a question: do I need to roll the fenders to avoid rubbing, or no need to do it if I just do a decent drop/not too low?
TIA
Postby omllenado » Sun Aug 02, 2009 12:35 am
You don't need to unless you're going crazy low.
And if you are going crazy low :Endlinks but I doubt you'll need it.
http://www.ecstuning.com/Volkswagen-Golf_IV--1.8T/Suspension/Sway_Bar/
t0kie
Postby t0kie » Sun Aug 02, 2009 7:51 am
omllenado wrote:You don't need to unless you're going crazy low.
No, I don't plan to go crazy low. So I also need this inner sway bar insert? What do they do?
zero2sixtyr35
Postby zero2sixtyr35 » Sun Aug 02, 2009 1:47 pm
from my experience with aristos, i had to use spacers in the front to clear my front struts.
DucMike
Postby DucMike » Thu Aug 06, 2009 2:22 pm
My 20th is all the way down on PSS9s & GLI RCs and I don't rub at all. In fact, I did have to add 7mm spacers in the front to clear the adjuster rings on the struts & added 15mm spacers to the rear to balance things out. If you don't slam the thing, you should be fine.
Return to “VW Technical & Repair”
