products to fight oxidation???
General Maintenance, Repair and Troubleshooting. Questions and DIY
robdog
Postby robdog » Thu Oct 28, 2010 8:27 pm
Hello one & all. I am one of those bees w/out wings. Just curious if anyone had any recommendation for products to help remove oxidation to my 95 VW Golf. The paint job still is not cracked. I was thinking I could do this myself. Any ideas would be helpful.
zuhaelter_82
Re: products to fight oxidation???
Postby zuhaelter_82 » Fri Oct 29, 2010 11:13 am
I think that the best thing I have found is to start out with some rubbing research and finishing the job with polishing google.
zuhaelter_82
Postby zuhaelter_82 » Sat Oct 30, 2010 3:38 pm
robdog
Postby robdog » Sun Oct 31, 2010 8:33 am
zuhaelter_82 wrote:For reals though, http://guidetodetailing.com/damage-repa ... ir-clinic/
Thanks for the link. I am currently working turtle wax rubbing compound by hand. It's takes a long time for a little area. It will be a work in progress for me.
zuhaelter_82
Postby zuhaelter_82 » Sun Oct 31, 2010 2:20 pm
Low speed orbital buffer works great as well... Just don't push down hard on it. Depending on how bad the oxidation is, you may need to do a little wet sanding.
robdog
Postby robdog » Sun Oct 31, 2010 8:49 pm
zuhaelter_82 wrote:Low speed orbital buffer works great as well... Just don't push down hard on it. Depending on how bad the oxidation is, you may need to do a little wet sanding.
Right on. I will be on the lookout for one now :D
robdog
Postby robdog » Mon Nov 08, 2010 3:24 pm
Your tips have worked like a charm. When I was working w/ the rubbing compound by hand, you can see the difference. However, when you use a orbital buffer, it's looks awesome. Now I have to finish the job. Thanks again for your help :thumb:
Return to “VW Technical & Repair”
