1.8T (AEB) spark plugs...
BDF02M
Postby BDF02M » Sat Jul 21, 2007 3:28 pm
...where are they? A friend is wants to change the plugs on a '99 Passat, and can't find them. :eyes:
I looked at the DIY on vortex, but didn't find any instructions on how to do it or anything.
Anyway, the more info the better. :D
Thanks!
Erik
2003 GLI VR6
2008 Yamaha R6
BDF02M
Postby BDF02M » Sun Jul 22, 2007 12:37 pm
Thanks! :thumb:
Erik
2003 GLI VR6
2008 Yamaha R6
jduarte
Postby jduarte » Mon Jul 30, 2007 12:05 pm
Sureguy wrote:1) Take off plastic cover on top of engine
2) Remove electrical plugs on 4 coil packs
3) Remove 8 5MM internal hex bolts holding coils to valve cover
4) Lift each coil pack out and place in order in safe place
5) Remove 4 spark plugs using 5/8" spark plug socket
Make sure you use F7LTCR Bosch plugs.
You can also cheap out and use NGK BR6KE plugs with stock gap. I was hurtin for money so had to cheap out on plugs, but I'll be going OEM again in about 10K miles :thumb:
