hks
jmac1
hks
Postby jmac1 » Tue Sep 11, 2007 11:48 pm
is d hks ssqv bov ok? would you guys recommend it? i have an aluminum canaster diverter valve which 034 motorsport put it runs good but on the top end sometimes it cuts off im not sure if thats the problem .but my daughter gave me a hks bov ssqv planning to install it might solved the problem any suggestions? :thumb:
Postby lunisport » Wed Sep 12, 2007 11:20 am
well, a DV is a bit different than a BOV, unless you can plumb the output back into the DV pipe to the airbox, then it'll be running in DV mode.
A BOV usually exits in the atmoshpere, which is why you hear car that goo 'woosh' or a whistle. A DV lets off pressure put recirculates it back to the intake.
I think you should check the DV if it has an adjustment somewhere, it might not be holding boost or something. I don't think I've seen a sequential BOV on a 1.8T or a SC'd dub before.
flip2jetta
Postby flip2jetta » Wed Sep 12, 2007 1:01 pm
I just know you're most likely going to run rich if you use it because the engine expects that air to be redirected back in, not released to atmosphere.
jmac1
Postby jmac1 » Wed Sep 12, 2007 4:53 pm
Thanks
square_one
Postby square_one » Wed Sep 12, 2007 11:22 pm
just get the forge 50/50 splitter for the sound you want and enough recycled boost to not throw a CEL.
http://forgemotorsport.com/content.asp?inc=product&cat=1705&product=FMDVSPLTR
87 GTI 16V
Postby omllenado » Thu Sep 13, 2007 5:43 pm
HKSSSQ?
Sweet sound but not worthit...Car goes into limp mode most of the time. Been there 2x.
oldskoolvwlover
Postby oldskoolvwlover » Fri Sep 14, 2007 11:59 am
easiest way to explain it is like this
ANY TIME you blow off metered air your car will not be running properly, even if you don't get the cel. Once the air has been metered the ECU is fueling for air that should be there, so you will be wasting gas and hurting performance all at the same time.
If it ain't broke, don't fix it.
jmac1
Postby jmac1 » Wed Sep 19, 2007 1:12 am
i tried using it it sounds good but i lost power im going back to the old diverter valved thanks again for the advice
oldskoolvwlover
Postby oldskoolvwlover » Wed Sep 19, 2007 12:07 pm
:thumb: :thumb: :thumb:
