Future Upgrades
Future Upgrades
Postby diz_gti » Sun Nov 11, 2007 11:19 am
My future plans after i get control arn bushing and new tie rod
list to be done in order
TT Chip
Eurosport cool flo RACE intake [CAI]
Eurosport Underdrive pulley
BBM big bore intake
Autotech Stainless 2.5 exhaust
TT headers or Bosal
suspension
Autotech front stress bar
Autotech rear stress bar
WRD front lower stress bar
Weitec TX Suspension 3.15 front 2.25 rear. Current set up wietech 2.25 front ans stock haight rear with bilstien shocks, i want to go lower
then rims, 15 or 17s
Postby diz_gti » Sun Nov 11, 2007 12:16 pm
thanks for the info
il just go the way i was going to do it the first time... list changed
Postby diz_gti » Sun Nov 11, 2007 12:31 pm
even with a aftermaket highflow TT cat?
Sureguy wrote:You don't necessarily need a carb approved chip. Unless the smog shop knows you have a chip they will never know. Also if you are worried about being CARB legal you cannot get a header as they are not allowed on OBD2 cars. The reason is for heat retention in the exhaust system.... your catalyst needs heat to work (about 1200deg) and a tubular header cannot retain the heat needed to keep the cat efficient. The result is a P0420 code (catalyst efficiency).
Postby diz_gti » Sun Nov 11, 2007 12:42 pm
what if i use no cat? :) doesnt TT have a header that deletes the cat for the 2.0 8v? i can always put back the stock headers before smog.
Postby diz_gti » Sun Nov 11, 2007 1:10 pm
:thumb: [quote="Sureguy"]You could but that would be illegal ]
Postby diz_gti » Mon Nov 12, 2007 11:23 am
snyone wanna buy a used ABA block so i can buy this>? :)
Eurospec Sport - Short Block - 2.2L 8v - Full Forged Internals
Quantity in Basket:none
Code: 037100033-2v
Price:$4,500.00
Shipping Weight: 100.00 pounds
Enter Compression - Between 8.5:1 - 14:1:
Quantity:
Fully built 2.2L bottom end for the 8v motors. Uses the 236mm "tall" block, for crossflow or "u-turn" type heads. Headwork and performance camshaft is highly recommended, not included.
INCLUDES THE FOLLOWING:
-Forged 4340 100 mm stroke Crankshaft
-Eurospec Sport H-Beam 159 mm connecting rods w/ARP 3/8" bolts
-Forged JE Piston's in your choice of compression
-New oil pump
-Main bearings, German high performance
-Rod bearings, German high performance
-Steel head gasket
-Main Bearing girdle with ARP hardware
-Oil Pan
Postby diz_gti » Tue Nov 13, 2007 12:43 am
Sureguy wrote:FYI... I have an account at Eurospec Sport
how much can u get the built block for?
hiphopn
Postby hiphopn » Mon Dec 03, 2007 8:02 am
i was wondering why your title was nuespeed and then you made no mention of neuspeed in the post. but i see james told you whats up. yeah im not a huge fan of neuspeed either. oh and that block is alot of money. i wish i was rich and could buy that kind of stuff without worrying about paying rent :p
Postby diz_gti » Mon Dec 03, 2007 10:45 am
You aint the only one thats stuck with rent and other bills. Yea i changed the title. maybe the only neuspeed item im getting is the SC, but its still not enough to keep up with you. but we all got different goals. :thumb:
if i had the money i would buy that eurospec block like its candy :wiggle:
