suspen setup.
Performance and tuning enhancements for your VW
functionisform
suspen setup.
Postby functionisform » Sat May 17, 2008 1:15 pm
Looking around at coilovers for my mk4. I want to tuck my stock 16's whats the mininum drop i will need. I know you need spacers also what size should i look for? and is there anything else needed?
Postby diz_gti » Sat May 17, 2008 9:35 pm
Vmaxx
functionisform wrote:Looking around at coilovers for my mk4. I want to tuck my stock 16's whats the mininum drop i will need. I know you need spacers also what size should i look for? and is there anything else needed?
hiphopn
Postby hiphopn » Sun May 18, 2008 9:01 am
well most of my vw knowlege is based on mk3 but i dont understand why you would need spacers id you dont now, to clear the brakes. your struts dont move. now if you got a thicker strut (coilovers are ussually thinner) then you might need spacers but not cuz you are lower. if you do need spacers for some odd reason then how are we supposed to tell you how thick, if you dont tell us how wide your wheels are and the offset on them? i think tucking a 16 on a mk4 is a pretty healthy drop. why dont you install the coils and then all your questions will b answered and your car will be lower.
:thumb:
Postby diz_gti » Sun May 18, 2008 1:30 pm
here is my car on 17x7.5 with 42 offset. no spacer needed in the front tires just barely rub in the fenders. i got 1/4 spacers on each side in the rear just to get it a slight wider look on weitech 60mm drop up front and stock haight in rear
HumboldtCorrado
Postby HumboldtCorrado » Mon May 19, 2008 12:26 pm
hi.
i don't have coils, but i do have a mk4 on 16's with spacers. i'm dropped on koni yellows/H&R race springs, and i'm not tucking the tires yet. anyway, here's an old picture of my ride on the races (~2" drop), with 20mm spacers out back and 8mm in the front. i know there's a dude local (jeremiah) that has some Koni coils he's looking to get rid of...
the spacers seem like a really good fit, and if i was any lower, i'd literally be dragging my skidplate on every little bump (i'm pretty much there now).
functionisform
Postby functionisform » Mon May 19, 2008 4:40 pm
very nice cars. gives me a little idea of what im up against. the gti's tails are clllleeeaaannn. the minium drop i want is 2.5.
HumboldtCorrado
Postby HumboldtCorrado » Mon May 19, 2008 7:13 pm
if you're going for at least a 2.5" drop on 16's, you're gonna be low. if you don't get a skidplate, pick up a spare oil pan or two. :rolleyes:
Postby diz_gti » Mon May 19, 2008 9:35 pm
of you want to go kinda budget. weitech has springs 80mm drop up front and and you can go 60 in the rear. whatever shocks you wanna get, i have 60mm
kurdus
Postby kurdus » Tue May 20, 2008 1:05 am
koni coils all the way down f/r with perches still in. no spacers needed. but some kind of adjustment to the sway is rec'd. youll rub axle and sway on the smallest thing. one finger gap, not tucked. FK and B&G go low. koni, bilstein, kw, h&r, weitec... not so low, but all close the gap up nicely.
sorry for the incomplete sentences.
hiphopn
Postby hiphopn » Tue May 20, 2008 9:56 am
kurdus wrote:Image
thats all the way down? weak sauce! i cant even drop my car all the way down for it would be undrivable. i guess mk4s cant go low :rofl:
kurdus
Postby kurdus » Tue May 20, 2008 11:59 pm
hiphopn wrote:thats all the way down? weak sauce! i cant even drop my car all the way down for it would be undrivable. i guess mk4s cant go low :rofl:
on koni yes. there are others that go a lot lower. but as said, that takes work too. (notch, fsb, final et's, etc)
Turtle-Dude
Postby Turtle-Dude » Wed May 21, 2008 10:22 am
pansyboy8 wrote:does anyone else see the irony with the op's username and this thread?
but to stay on topic, you'll need at least a 3in drop to be tucked. are you going to be on stock wheels or after market, if you are going aftermarket, then its all about offset.
Caught the irony but...eh :thumb:
I'm going to go invest in the oe manufacturer of your oil pan. If you want me to make a fortune, get yourself a skid plate as Humboldt Corrado recommended. Does anyone other than DIESELGEEK make one?
HEY! What happened to the old skid plates?
Found this one too.
Turtle
Thanks to:
Techtonics Tuning
Check out:
United States Naval Sea Cadet Corps
aggiepm wrote:What is Quaife? isn't that a vaginal fart?
lunisport
Postby lunisport » Wed May 21, 2008 11:14 am
Don't do this:
It may look cool, but you'll ride like hell with my old set up:
- Tokico Blue shocks
- Cut VR6 Neuspeed Sport front springs
Newer setup:
- Bilstein Yellow shocks
- Neuspeed 1.8T Sport Springs (uncut)
snowfox
Postby snowfox » Wed May 21, 2008 12:52 pm
zoso wrote:get a skid plate
Good Lord! That looks like a road kill smear on there...
1989 Fox Wagon GL
2.0 ABA - GTI head - Hydro "G" - big TB - TT pipes - E30 Mounts - PSA 5spd - Neuspeed Coils - Bilstein Sports - Ronals - 10.1's - ADDCO bar
Postby diz_gti » Wed May 21, 2008 10:20 pm
yea he wanted to see the squirrel reflex. but it turned out it doesnt have cat like reflexes :rofl:
snowfox wrote:Good Lord! That looks like a road kill smear on there...
Postby diz_gti » Wed May 21, 2008 10:21 pm
hey ermin. thats a $270.00 dollar fine for parking in the redzone
lunisport wrote:Don't do this:
Newer setup:
Postby diz_gti » Wed May 21, 2008 10:23 pm
that dent puller guy fix your hatch?
Return to “VW Performance Upgrades & Tuning”
Users browsing this forum: No registered users and 2 guests
