Which DV to get?
slowmofo
Which DV to get?
Postby slowmofo » Mon Dec 22, 2008 11:37 am
For my 02 1.8t jetta? FMDV007PA, FMDV007P, or the FMDVSPLTR? which sounds the best and which is the best for the car?
slowmofo
Postby slowmofo » Mon Dec 22, 2008 12:24 pm
installed the neuspeed CAI on my car already, how loud will it be? will be screaming WAHHHHHHHHHHHHHHH as i go down the street? What should I expect from installing the DV on more turbo whoosh sound?
00TURBO
Postby 00TURBO » Mon Dec 22, 2008 9:03 pm
slowmofo wrote:installed the neuspeed CAI on my car already, how loud will it be? will be screaming WAHHHHHHHHHHHHHHH as i go down the street? What should I expect from installing the DV on more turbo whoosh sound?
wont be screaming. just a little more noise from the hood. if you go with a reg dv rather than hybrid or bov it will "whoosh" but not obnoxiously. :]
00TURBO
BigFuchnJoak
VWCRAZY
Postby VWCRAZY » Mon Dec 22, 2008 10:58 pm
A regular dv is the only way to go. If you run a split dv the car will not run as good as if you just get a regular dv. If you want the effect of a BOV then turn the dv the other way and you will get the same effect as having a BOV but with the benefit of a true dv
