bent camber
denzo337
bent camber
Postby denzo337 » Wed Apr 22, 2009 8:48 am
whats up fellas i have a 02 gti 337 i unfortuntely bapped the left driver side onto a curb and messed it kinda bad...... i replaced the control arms ball joints axel and bearing..... but my boy tells me when i tried to get it alligned that my left side was a whole dergree off. my question is would a camber kit fix it or should i replace the strut as well
denzo337
Postby denzo337 » Wed Apr 22, 2009 10:32 am
what do you think could be bent to make it a whole degree off? cuz i replaced everything that was bent like the axel control arm and ball joints......
denzo337
Postby denzo337 » Wed Apr 22, 2009 2:21 pm
there is really no shop around where i live that i really trust do you recomend a shop?
denzo337
Postby denzo337 » Wed Apr 22, 2009 3:36 pm
for sure will do, another question if my subframe is a lil tweaked would that be the reason of my camber being bent?
denzo337
Postby denzo337 » Wed Apr 22, 2009 3:40 pm
sure guy i will definately be contacting you......the reason why i asked if the subframe is tweaked is because i impacted the curb on the driver hand side at about 35 to 45 mph it was a pretty rough impact....
Postby diz_gti » Wed Apr 22, 2009 4:43 pm
I wouls also say bent strut/shocks. I just recentky pu coilvers on my car 2 weeks ago. Before I did that my steerinf wheel was like 15 20* to the left. When I pit in the coilovers my steering wheel Went dead center. Its not to the left or right. Its right in the middle. Yea have james check it out. But changing my shocks fixed my steering alighnment problem.. if u have stock suspension. Now is a good time to upgrade since your gona have pull your suspension.
Sorry I'm posting from a cell phone. Small buttons
denzo337
Postby denzo337 » Wed Apr 22, 2009 6:30 pm
definately thank you, james i dont have any free time till probably some time next week but im definately trying to fix this problem as soon as possible and ill be contacting you thru the forum or thru email.
Postby diz_gti » Wed Apr 22, 2009 7:19 pm
Sureguy wrote:Lorenzo your problem was caused by camber which is adjustable on your car at the bottom of the strut. The MK4 uses a slip-in strut so therefore there is no camber adjustment.
gotcha
