40k maintainence recommendation, none dealship
ogg
Postby ogg » Mon Nov 09, 2009 2:30 pm
I am sure this has been an old discussion.
I have a 04 passat and deal ship quote my 40k service at over 800 dollars.
I am really fed up with deal ship at this point, I dropped over 15 hundred there after warranty expired. The car is a decent car. Dealship always recommend O2 sensor replacement and CVS boot need repair....
Anyway, any recommendation for a decent independent shop around Fremont area?
Thanks in advance.
Postby diz_gti » Mon Nov 09, 2009 10:05 pm
up for ozsport .he worked on my car many times
IrishGLI
Postby IrishGLI » Tue Nov 10, 2009 8:42 am
x3 for ozsport. Both Jim and Jon have tons of experience working on cars, do top notch work, and surpass many other places on not only service work but performance work. I try to do all work on my GLI myself, but anything that's beyond my experience or time limits I'd take to ozsport and only ozsport.
Clean and Serene
The way I live my life now is my amends to the world.
ogg
Thanks guys
Postby ogg » Tue Nov 10, 2009 11:24 am
Here is the list of tasks to be done:
4 Cyl.
Replace engine oil and oil filter 0.00
1030 Replace oil drain plug gasket 0.00
1040 Rotate tires, inspect wear and adjust pressure 0.00
1050 Replace air filter element 0.00
2010 Replace pollen filter element 0.00
2020 Replace spark plugs 0.00
2030 Install fuel system treatment 0.00
2040 Install engine oil treatment (not available) 0.00
2050 Install windshield washer fluid 0.00
2060 Change Trans fluid & filter (if applies)-add charge will apply 0.00
2080 Visually inspect for fluid leaks 0.00
2100 Check heating & air conditioning system 0.00
2110 Check vehicle restraint system 0.00
2120 Check power window & door lock operation 0.00
2130 Check head lamp for proper aim 0.00
2140 Check dash panel, interior & exterior lighting 0.00
2150 Check & adjust rear wheel bearings (if applicable) 0.00
2180 Lubricate transaxle shift linkage 0.00
2190 Lubricate parking brake cable guides 0.00
2200 Lubricate body hinges, latches & lock cylinders 0.00
2220 OBD - Check DTC Memory and Purge 0.00
2240 Add cooling system conditioner 0.00
2280 Brake fluid exchange 0.00
2292 Perform Battery Service MOC 2871 0.00
5030 Balance 4 wheels 0.00 0
5150 Fuel induction / throttle body service 0.00 0
5240 Cooling system fluid exchange 0.00 0
5310 Premium Brake fluid exchange upgrade 0.00 0
Including the following inspections:
3010 Body: Visual inspection for corrosion 0.00
3020 Under body sealant for damage 0.00
3030 Door check straps (lubricate if needed) 0.00
3040 Rear spolier & lubricate if needed (New Bettle Only) 0.00
3050 Brakes: inspect system for leaks, and fluid level 0.00
3060 Coolant level and frost protection 0.00
3070 Convertible roof, funtion & damage. (if applicable) 0.00
3090 Sun roof frame (clean & lube if needed) 0.00
3120 C.V joints for leaks or damage 0.00
3130 Suspension & Tie rod ends for excessive play or damage 0.00
3160 Exhaust system for leaks and damage 0.00
3170 Power steering fluid level (if applicable) 0.00
3190 Windshield cleaning nozzle function 0.00
3210 Wiper blades functionality 0.00
3220 Ribbed belt, conditon & tension (if applicable) 0.00
3230 Inspect tire psi: LF_____ RF_____LR_____RR_____ 0.00
3240 Inspect tire condition LF_____RF_____LR_____RR_____ 0.00
3250 12V starter & auxiliary battery (if applicable) 0.00
3260 Haldex clutch fluid level (if applicable) 0.00
3270 Inspect battery & report condiiton Pass_____ Fail______ 0.00
3280 Inspect brake lining LF____ RF____ LR____ RR____ 0.00
3290 Check & top off all fluids 0.00
3300 Lubricate chassis, suspension & steering joints 0.00
Minimum Service Total $ 599.95
IrishGLI
Postby IrishGLI » Sat Nov 21, 2009 9:07 am
Sureguy wrote:or Ozsport featuring Ermin lol
Touche!
Clean and Serene
Postby lunisport » Mon Nov 23, 2009 7:26 pm
:rofl:
denzo337
Re: 40k maintainence recommendation, none dealship
Postby denzo337 » Wed May 05, 2010 9:00 pm
i agree with everyone james and jon do good ass work, i brought my car to them many times and will continue to bring my car to them! im from union city and there shop is cambel not to far at all
