Euroimagetuning Solutions Xmas Sale.
Sell/Trade your VW parts
Brandon@Euroimage
Postby Brandon@Euroimage » Mon Dec 20, 2010 8:16 pm
http://www.euroimagetuning.com/
Wanted to give everyone enough notice on our sale. 20% off on ALL our machined products (in stock items only) while supplies last.
BBS RC/RS Flat Caps:
We are proud to bring you our very own BBS RC Flat caps for OEM VW BBS RC wheels. Our design gives you a whole new look on your OEM wheels.
Motor Mount Spacers:
Do you have axle binding issues? Would you like to effectively raise your motor? Do you need to get your oil pan off the ground on your slammed MK4? Here is your solution!
Mk4 Wiper Delete Solution:
Our wiper delete plug has been designed specifically for the Mk4! It features a smooth domed cap which is threaded on the back. A knurled nut allows easy install and a rubber O-ring allows a water tight seal. A simple – yet effective package to clean up the rear of your Golf, GTI & Jetta wagon!
Half Caps:
Do your strut caps pop up in your engine bay? Do they even rub the hood? These caps are the answer. We have developed the “Half Cap” strut caps to increase hood clearance on cars suffering from worn out strut bushings. For use with OEM or Density Line bushings.
We here at EuroImage Tuning have come up with a solution for replacing the broken adjusters on your mk4 OEM HIDS. No more shrugging it off as it doesn't need to be adjusted, you can finally protect your investment and ensure they function as they should. Sold in a kit per headlight (2 adjusters). Please note that photos show prototypes, production versions are machined pieces.
Return to “Classifieds”
Users browsing this forum: Bing [Bot] and 1 guest
